help lowering hatchback
RE: help lowering hatchback
A mild drop all you need are the springs, you will end up with rear camber right on the edge of in specification. You can correct this camber with camber correction links. I highly recommend keeping the camber at nominal to avoid excessive tire wear.
It's a fairly straightforward install if you just put in the springs, if you want the camber links installed, you have to drop the rear suspension carrier ~1-1.5" to get clearance for one of the camber link bolts to come out (it's the top most suspension link in the rear suspension.)
No...springs drop the car, but when you lower it, the tires will tip inward at the top (causing excessive wear on the inside edge of both rear tires.) The camber links are a little longer than stock and will correct the camber back to within stock specifications.
There are 3 different things to keep in mind with tire position: Camber, caster and toe
here's the easiest way to explain it:
Toe
Stand with your feet parallel, (imagine they are your tires on either the front/rear suspension)
now point your toes inward toward each other, this is "toe-in" the opposite is "toe-out" Toe helps with the self-centering characteristics of the car, but excessive toein/out can wreak havoc with your suspension/tires
camber
Now with your feet parallel, make your legs go bowlegged (knees spread farther apart than your feet), your legs represent positive Camber (top of the tires tipping outward), positive camber is bad. Now tip your knees in, that is negative camber, negative camber helps with the handling of the car, but excessive camber can wear your tires on the inside edge real fast.
Caster
This is really a front suspension characteristic. Imagine a centerline drawn from top to bottom down the side of your tire (through the hub), now rotate this line clockwise a little. The angle from vertical to the line is the caster angle, the amount of caster affects the steering characteristics of the vehicle.
On the rear suspension of the Mazda3, there are adjustments available for everything except camber, so by replacing those links with longer ones, you can get your tires back to a slight negative camber position (about -0.2 degrees, without the links I was at -2.1 degrees)
FYI....The springs always set the ride height of the car. (whether they are air springs, coil springs, torsion springs, whatever.)
Toe
camber
Caster
lowering/dropping are the same thing.
Springs are around $200, camber links are about the same....I did all of the installation myself.
Eiback springs (Pro-kit) & Mazdaspeed Camber Links are what I used....I've had VERY good experiences with Eibach springs.
ok let me get this straight the springs lower the car and the camber links balance the car so their is not as much wear on the inside of the tires and if i want everything it would be about 400 dollars
