insterment lights
insterment lights
ok i know i am not stupid but when i turn my lights on my speedometer, my tac and gas all dim a great deal. I know where you turn your lights on they are suppose to dim alittle.I just recently dissconnected my battery to check it and ever since then it has gotten very dark when i turn on my lights. if anyone has any suggestions that would be much appreciated thanx
RE: insterment lights
You can also adjust the daytime lighting using the button/stalk that's on the left upper instrument cluster. The default is maximum, but can be adjusted lower. This will affect how bright/dim the nighttime lighting is too. With the lights on, that stalk switches from nighttime to daytime lighting only.Any permanent adjustments must be made with the headlights in the off position.
Check out the owners manual for further details.
ORIGINAL: virgin1
anthonytsi
11-12-2008 04:37 PM
Rooster
12-02-2004 09:37 PM
