Interchanging parts between the sedan and the hatchback
Old 10-04-2007 | 04:13 PM
Shawne's Avatar
Default Interchanging parts between the sedan and the hatchback
First of all I am new here and I did try to search the forum for answers, but failing that I have posted the following.
I have two 2004 Mazda 3's, 2.3L, one is a 5 speed and the other is automatic. One is the 5 door hatchback model and the other is a sedan. Same colour, same engine, etc. Trouble is one has been hit in the rear (Sedan -A/T) and the other has been hit in the front (Hatchback 5-Speed). I am wondering which parts are interchangeable from the Sedan to the Hatchback? I need to replace the rad support, ac condensor, Radiator, W/washer fluid bucket, altenator, Power steering pump, etc.
Is there a way I can find out which parts are interchangeable?
Thanks.
[IMG]local://upfiles/13667/66664C8E8B8D49D3B464E37BA67DF121.jpg[/IMG]
[IMG]local://upfiles/13667/6D37EFC91E5549379A79485B4D737E5E.jpg[/IMG]
Old 10-04-2007 | 04:24 PM
shalezoom3's Avatar
Default RE: Interchanging parts between the sedan and the hatchback
alot of the stuf you mentioned should be interchangable...except for the radiator support. I believe that is different.
You can always bug Mazda over and over agian comparing parts numbers.
But alot of engine and suspension stuff is the same. Just not body panels etc...
Old 10-04-2007 | 08:39 PM
jaimie08mazda3's Avatar
i would assume they would be interchangable. maybe look on the internet or talk to a mechanic from mazda to get the thumbs up or down
Old 10-05-2007 | 09:45 AM
Lupae3s's Avatar
did your 5-door 3s crash into the back of your 4-door 3s?
Old 10-05-2007 | 10:34 AM
MrSpike118's Avatar
Most of them should be obviously except for the body panel. Think about it, is it cheaper or more expensive to make different parts for each car? The 6;s fog lights that were integrated into the headlight assembly were moved to the lower fearing, but they just replaced the foglight with a fake looking thing. They coul dhave changed the headlight unit, but it was an unnessacery (sp?) cost. So I dont think they would change anything in the 4 and 5 door unless it was nessec.
Old 10-05-2007 | 01:16 PM
Shawne's Avatar
I spoke to Mazda today and they basicall said anything mechanical should switch over aside from the radiator because one is a standard and the other is an automatic. Other than that though steering box, A/C condenser, rad support, wiring harness, etc, should all be interchangeable.
Thanks for the quick responses guys. Also, No, the 5 door did not rear end the 4 door.
Drummerguy2009
08-01-2009 03:06 PM
paulgraham
05-21-2009 01:10 PM
Joe1989
02-01-2008 12:20 AM
00protegeracer
07-20-2007 07:33 PM
Metalone
04-18-2006 01:11 PM
Quick Reply: Interchanging parts between the sedan and the hatchback
