Like a ... virgin!
Old 08-10-2008 | 12:50 AM
UrbanmanUSA's Avatar
Default Like a ... virgin!
I created some redneck self jack stands, took 2x9's, sawed them in half (45 degree angle), duct taped together the lumber ... voila!
Old 08-10-2008 | 12:54 AM
Default RE: Like a ... virgin!
It would be almost IMPOSSIBLE to do a change without stands, or a pit- to even slide under the car to get at the drain plug without the car being raised, seems simply not do-able..
Old 08-10-2008 | 12:56 AM
I don't see how the filter can be removed without oil being spilled. Note to DIYers - wear a shirt you can toss. And, allow time to clean (rinse) dirty oil off the lower shield after the change.
Old 08-10-2008 | 01:01 AM
Summary: Felt great to do it, use MY oil and filter choices, oil level EXACTLY correct!
Old 08-10-2008 | 01:06 AM
FYI, Like A Virgin, is an 80s Madonna song.
Old 08-10-2008 | 07:23 AM
Were you drinking?I don't understand this thread at all.
Old 08-10-2008 | 11:18 AM
When the board has tech issues, and you have to breakwhat you want to postinto small bits, it is less coherent than ideal. Of course, it is about me doing my "virgin" self oil change (first time I've done it on the M3).
Old 08-10-2008 | 01:49 PM
Siber Express's Avatar
I jack up the right side, jackstand under the front suspension and drop the plastic engine protector while the oil is draining,
Old 08-10-2008 | 01:50 PM
change the filter and reasemble with the Mazda cartridge, put in my4.5 quarts of 5w/20 Motorcraft and off to the races I go [8D]
Old 08-10-2008 | 04:00 PM
I was able to do it without dropping the shield (protector), but my engine has a more simple spin filter - for which I am grateful.
