little things
RE: little things
ORIGINAL: LordChrisofSith
Not sure I like the glued on wheel weights.
I wouldn't worry about that, Chris.
In the old days sticky (double-sided tape) weights or "stick-ons" as they were known would fly off all the time because the adhesives were not that good.
Adhesive technology has come far since then and I'm sure having a weight come off again is a rare thing.
RE: little things
ORIGINAL: dentinger
if the wheel wieghts are on the lip of the rim, they are just hammered on.
if they are inside the wheel rim, they are glued on (sticky weights, as we call them).
RE: little things
Wheels and tires are never perfectly balanced on there own. And especially when the two are put together they need to be balanced so as not to have uncontrollable vibrations.The tiremight be heavy on one side while thewheel is heavy on that same side when put together, you see?Even just having the valve stem on one side of a wheel throws it's balance off. The only practical solution is to balance them both as a set.
RE: little things
i change them in my auto shop class haha. we got a wheel balancer and im like awesome at balancing tires. but when i saw mine im like wtf i didnt understand lol how do i take thooose ones off lol
RE: little things
ORIGINAL: dentinger
uh, this 1x2 hole in the bumper? you mean the small circle on the passenger side of the car?? that so that you can rescue workers can put a tow hook in there if the need be.
its also good for racing and such.
My guess was it isthere so those in colder climates couldrun a block heat power cord through the bumper.
If I did punch it, I don't see why water coming in that little hole would be troublesome.
I've driven in quite a bit of rain, my engine compartmentis amazingly clean, so I don't think a lot of watercomes in through the front of the vehicle.
RE: little things
That plug pops out to expose a captured nut inside the REAL bumper. There's a tow hook (screw) that hold the jack inplace @ the back of the car. If you unscrew the jack, that tow hookcan be screwed into the threaded hole in the bumper once the cap is loosened.
RTM for further information.
RE: little things
ORIGINAL: dentinger
[IMG]local://upfiles/339/DA784F68EB4F4094BE8E7EED1826E340.jpg[/IMG]
[IMG]local://upfiles/339/ED354E748BD2485093DB978DE6A45407.jpg[/IMG]
RE: little things
ORIGINAL: virgin1
I have a 1"x2" hole in the radiator support behind the grill to the left of center as you face the car. Is that what you're talking about?
As for the rear vent on the i-sedan, you can see it from outside of the car by looking through the bottom of the rear window, initially I thought it's pretty useful lto have a vent there, but reallized it's just a decal.
________
butt Cams
