little things
#41
RE: little things
ORIGINAL: wineye
I got around to take a few pictures for you. It's hard to show anything for the rear window vent (pix1), but I am posting here, along with te front radiator frame (pix2).
I am also asking a question since I found that there's a connector under the radiator frame top edge (see pix3), anybody know its use? thanks.
1. Re: the rear window vent, Mazda3 is not the only vehicle that has a vent back there. My neighbor's Jetta has similar vents back there. Purpose? I don't know. Maybe it allows the trunk to ventilate?
2. I have that square hole, it is really high up, I'll look next time after I drive in the rain to see if I get water coming in there. I don't see anything on mine directly behind the hole that looks like it wouldbe particularly sensitive to water.
#42
RE: little things
ORIGINAL: SPeeDy3
now that you mention it.. i miss gear more on this than i did on the civic.. when i go into third i make sure i clutch alllllll the way down and i let it sit in neutral for a second before i shift completely. i always thought that the aftermarket bushings would make a difference. if i change to the TWM short shifter and the TWM bushings, would it correct the "missing third gear all the damn time" problem?
________
MIKHAIL cam
#43
RE: little things
ORIGINAL: UrbanmanUSA
Thanks for the pics,wineye.
ORIGINAL: wineye
The 1x2 in hole that we talked about isn't a big deal, even if water gets in it'll hit the intake manifold, which is made of high-strength plastic.
________
Avandia class action lawsuit
#44
RE: little things
ORIGINAL: krimsonviper
does that include the low model 3i? because if thats the case, i think im definately ready to get me some power windows/power locks in my car. tired of using the key
ORIGINAL: dentinger
something i really like:
everything is pre-wired.
ie,if your car doesnt have fog lights, all you need is the foglights, and a new light stalk, and thats it!
and apparently its the same for power mirrors, doors, windows, etc etc. but for those you'll need the solenoids, motors, etc etc
#46
RE: little things
ORIGINAL: wineye
(To Virgin as well, thanks for the tip on the connector), I'm gonna poke around on the rear window vent, to see if the bottom is movable.
ORIGINAL: wineye
________
Avandia lawsuites
mazda guy
11-27-2006 11:37 AM
