MAF of AFM??
MAF of AFM??
I bet no one really has this question, what is the difference between an AFM (air flow meter) and MAF (mass air flow). In case you did wonder, here is the answer:
MAF: mass air flow sensor, located before the air filter on the air intake. It measures the amount of air flow controlling the air/fuel ratio.
AFM: The air flow meter measures the intake air flow rate by measuring a part of the entire flow. Measurements are made in such a way that the ECU receives electrical output signals varied by the amount of heat emitting from the hot film placed in the stream of the intake air. When intake air flows into the intake manifold through a route around the hot film, the heat generated from the hot film is taken away by the air. The amount of heat reduction depends on the air flow. ...
I believe AFM uses rate to measure air, and MAF uses vacuum or something like that.. Import vehicles typically use AFM and domestic’s such as Ford/Chevy/GMC use MAF as well.
Going off of this information, I would say that the Mazda, being an import, would use an AFM, which is a sensor on the accordian hose before going into the intake manifold. Please correct if wrong.
RE: MAF of AFM??
interesting, where is the sensor located and what size is it. what i would like to know as well is the size of intake hose, where it connects with the stock air box, does anyone know that? also, looking in the manual, there is a fuse for the AFM, but nothing is listed for an MAF.
RE: MAF of AFM??
AFM and MAF are interchangeable terms. They both do the same thing. Different auto mfgs. use different termanology. Example, Mazda uses ISC which means Idle Speed Contol and GM uses IAC which means Idle Air Control...they both do the same job. When you were saying that one of the terms you used work off vacuum, they both do. The engine creates a vacuum no matter what when it is running. The modern MAF works off the hot wire sensor and the older ones work off a spring loaded door that opens wider when the throttle is opened up more.
RE: MAF of AFM??
I am going to assume thats what it is, so in a CAI, there has to be a place for that to plug back in, and someone cannot just remove the box and replace with a cone filter. so there goes that idea.
theguy
12-15-2006 12:00 AM
