Manual shifting trouble
New to the forums.
Had a question about my car. 2010 Mazda 3 manual transmission. When my car sits in the cold, I have trouble going into first and second, but no other gears. Could it be worn syncro's I'm guessing since every other gear is fine shifting?
This is a fairly new car, so there shouldn't be much wear on the synchros yet, unless it has been abused.
How much play do you have on the clutch pedal? Play means: free travel until you feel the resistance by the clutch spring. There should be about 1".
Consider having the transmission oil replaced with a synthetic variety.
don't tell me the 3 is a girly car!
X2. Use a multi viscosity oil. Sycronizers are brass, but unless you "grind gears" at shifting, these should be far from worn out. I've been in a few manual trannys (never a mazda) and to find basically any gear bad (non race car) is rare. You will have normal mesh wear over mileage. Clutch travel, or "toe play" at 1 inch is something I would prefer also, I don't "ride" the clutch. Toe play is built in for those that do.
