Mazda 3 A/C Compressor Oil? Atmos GU10?
Hi all,
New here and just working on my g/f's 2004 Mazda 3 2.0L w/66k this weekend. Yesterday I replaced pads/rotors, bled the system, rotated tires, oil/filter, replaced manual trans oil w/synthetic 75w90, air filter & NGK factory plugs. Pretty simple to work on so far, however I'm not familiar with some things...
Her A/C compressor locked up a few weeks ago and so I ordered a used A/C compressor which I am going to install today (system evacuated), but I have a question about which compressor oil to use? The factory service manual states using PAG oil Atmos GU10 compressor oil although I can't find any info on this oil. Is this a standard PAG oil I can find at auto parts stores?
Thanks!
Edit: Just found this is a PAG type 46 oil...
Thanks!
how did your ac replacement go? how much oil did you drain/add to the used compressor. I just did mine and things didn't go right, I am getting high low side pressures and low high side pressure. I can't think what is wrong except that maybe i added too much oil. I drained 2oz from seized motor, and about same from used motor, but I ended up putting 5oz of oil back into used compressor. AC guy says that wouldn't cause my problem, he said my used compressor was bad.
Thanks for any help
Thanks for any help
Jourdan_d
04-30-2013 12:19 AM
depfer1
06-02-2006 05:12 PM
sabanab35
07-18-2005 09:56 PM
