Mazda 3 starting troubles
Old 03-17-2007 | 09:21 PM
mazda jay's Avatar
Default Mazda 3 starting troubles
hey! I have a Mazda 3 2.0 (think you guys call it the 3i?)
anyways, when sarting in the morning from cold it takes about 6 seconds of turning before it fires up, seems long to me! anyone else experienced this? it is run on 95RON fuel as the handbook states? although it has had a little 97RON when i first got it. but shouldn't make a difference i would have thought?
Old 03-18-2007 | 06:25 AM
mazda jay's Avatar
Default RE: Mazda 3 starting troubles
no one else had this then?
Old 03-18-2007 | 03:18 PM
alant's Avatar
Hi MazdaJ
No had no probs of this type with my sport..
Are you on the new UK forum www.mazda3forums.co.uk
suggest you ask there. My forum name is gongoozler. Cheers!!
Old 03-18-2007 | 05:10 PM
mazda jay's Avatar
how hard have i been lookin for a uk forum and not come across that one!!!! cheers man! may get more of a response over there!
Old 03-19-2007 | 10:46 AM
chefmaster25's Avatar
How cold is it? It's pretty normal for a car to start up kinda rough or take a bit to start when its cold. Mine does the same thing when its real cold.
Old 03-19-2007 | 01:32 PM
dentinger's Avatar
mine just idles at about~1500 rpm, (instead of the usual ~800) until it gets warmed up, then the idle speed slowly drops down to normal
Old 03-20-2007 | 09:52 PM
babyhuey's Avatar
Fuel pump check valves in the pumps have been a considerable problems on the 3 that creates that exact condition mazda jay. The check valve allows all of the fuel pressure to drop off and then even allows the fuel to drain back out of the lines to the tank so it takes quite a while of cranking to get fuel pressure/ volume built back up.
If the car does this pretty much every morning then try cycling the key from off to run position 3-4 times. Every timeyou cycle the key the fuel pump will run for a second or two. If it then starts right up is a very good indication of pump check valve.
jonesjp
04-14-2015 05:13 PM
Irdium
06-01-2014 10:53 AM
Jw115589
08-04-2011 09:30 PM
cawkazn
08-07-2010 09:39 PM
plutosmaster
04-23-2007 05:00 PM
Quick Reply: Mazda 3 starting troubles
