mazda3
#21
I found a ton of them on eBay with free shipping for alot cheaper and they fit your model year. Look at this on eBay:
MAZDA TRIBUTE 3 & 6 2.3 DOHC CYLINDER HEAD
http://bit.ly/WoUPEA
#24
i was takeing off the valves on the head you know those little cups for the valve adjustment for the intake and the exhaust i tipped the head over some fell out and now i dont know which is which. what do i need to do?
#26
The numbers are the shim sizes for adjusting the valves u need a set of feeler gauges to fit the shims in the correct spots. Once u get the valves assembled install the shims in and bolt the cams in then use a feeler gauge to figure out which ones are too tight. I'm not sure what the gap is supose to be but I imagine u can google it to find out. U will have to remove and I stall the cams a few times to get all the shims in correctly.
