mazdaspeed turbo in mazda 3?
not hard if you no what you are doin, but just throwing the turbo from one wont work, u need an standalone ecu, piping, ic, and you will only be able to give ur motor about 8psi, and if you have an automatic none if this will even matter cuz the trans is going to blow
I'm thinking a MUCH cheaper and more reliable solution would be for you to sell your car and buy a true MS3.
actually boosting the 3 is cheaper than getting a ms3, as for reliability it all depends on how well its put together.
N/A 3- 12k (older)
MS3- 22k (older)
10k in a reg 3 is more than enough to get it better than is ms3, about 3k gets it to the same as the ms3 while at that point you can already make it faster. again you have to know what to buy, and yes thats buying everything brand new
N/A 3- 12k (older)
MS3- 22k (older)
N/A 3- 12k (older)
MS3- 22k (older)
N/A 3- 12k (older)
MS3- 22k (older)
migueleitor
06-26-2008 03:57 PM
03, 08, 2010, brand, convert, mazda, mazda3, mazdaspeed, mazdaspeed6, na, put, reliability, speed, stock, turbo, turbocharging
