Multiple Error codes On a 2011 Mazda 3
Hello People!
So , My Brother got a mazda 3 2011 , 2.0lt Engine. And he is fixing it to make it his daily , I've got an Autel Scanner wich I used to scan my mercedes , and I plugged it in on the car. I don't really know much about mazda codes , because they sometimes are quite vague , and I really don't know much about the parts on these cars.
Here's the list of the codes it gave back, hoping some of you can explain what those codes could be. I only know about the power steering one, we already ordered the pump and it will be here by monday.
Thanks to everyone for your help!
PCM (Powertrain Control Module) ( 4 DTCs )
DTC Description Status
P0108:00-AF Manifold Absolute Pressure/Barometric Pressure Sensor
Circuit High CMDTCs
P0118:00-AF Engine Coolant Temperature Sensor 1 Circuit High CMDTCs
P2006:00-AF Intake Manifold Runner Control Stuck Closed (Bank 1) CMDTCs
P0303:00-27 Cylinder 3 Misfire Detected CMDTCs
TCM (Transmission Control Module) ( 5 DTCs )
P2709:00-21 Shift Solenoid F Electrical CMDTCs
www.autel.com MaxiCOM MK808 Page: 1/2
Other / Mazda / AXELA / MAZDA3 / Test Time: 2023-04-06 16:16:41 Report ID: MAXIA20230406
P0745:00-21 Pressure Control Solenoid A CMDTCs
P0768:00-21 Shift Solenoid D Electrical CMDTCs
P0773:00-21 Shift Solenoid E Electrical CMDTCs
P0713:00-21 Transmission Fluid Temperature Sensor A Circuit High CMDTCs
ABS (Anti-lock Brake System) ( 1 DTC )
U0401:00-68 Invalid Data Received from Electronic Control
Module/Powertrain Control Module A CMDTCs
RCM (Restraint Control Module) ( 7 DTCs )
C1946:FF Front Driver Seat Track Position Switch Circuit Open CMDTCs
B10A6:FF Driver Seat Belt Lap Pretensioner Circuit Open CMDTCs
B1231:FF Longitudinal Acceleration Threshold Exceeded CMDTCs
B1877:FF Driver safety belt pretensioner resistance is too high CMDTCs
B1932:FF Air Bag Circuit Open - Loop No. 1, Front Driver Side CMDTCs
B1994:FF Side Air Bag Circuit Open, Front Driver Side CMDTCs
B2232:FF Air Bag Circuit Open - Loop No. 2, Front Driver Side CMDTCs
IC (Instrument Cluster) ( 2 DTCs )
U0131:00-8A Lost Communication With Power Steering Control Module A CMDTCs
U0401:68-8A Invalid Data Received from Electronic Control
Circuit High CMDTCs
