Neutral Safety Switch on Mazda 3
Old 06-04-2010 | 10:52 AM
MyronCope's Avatar
Default Neutral Safety Switch on Mazda 3
I have a Mazda 3 2005 4 dr sedan.
Since yesterday I have only been able to start my car (usually) in neutral. I called my auto club yesterday since I could not start my car. The mechanic tried giving me a jump but that did not work.
When I tried to start the car in Park it would not do anything, no click. so the mechanic had me put the car in neutral so he could tow it but then i decided to try to start it in neutral and it worked.
The mechanic mentioned the "neutral safety switch" is probably bad. Someone at work mentioned I should find out if this switch is internal or external, because if its internal then probably take it to a dealer to fix.
some questions:
* has anyone had this issue on here?
* what did it cost to get it fixed?
* does anyone know the answer to the internal or external question above?
thanks
MC
Old 06-04-2010 | 08:20 PM
Tracker's Avatar
There is no such thing as a neutral safety switch for automatics, there is only a transmission range sensor, and yours is malfunctioning, its external but unless you know what your looking at and what to test and what the ranges are then its off to the dealer.
Old 06-05-2010 | 12:29 PM
icspots's Avatar
It also could just be the microswitch for "P" on the gear selector itself broken and not telling the computer the car is in park.
Old 06-05-2010 | 02:15 PM
Tracker's Avatar
yea, either way its a dealer fix
brp223
08-04-2022 12:51 PM
sealuva
04-22-2014 05:20 AM
MazdaTirol
11-08-2012 04:21 AM
willy3486
04-17-2008 02:15 PM
jasonvp
12-31-2006 10:12 PM
Quick Reply: Neutral Safety Switch on Mazda 3
