Noticed my headlights dim!!
Old 02-29-2008 | 03:10 PM
2.0Mazda08's Avatar
Default Noticed my headlights dim!!
well today i started my car when i was leaving work the headlights were bright at first but the second i started to drive off i noticed they dimmed a bit and stayed like that....voltage stabalizer?
Old 02-29-2008 | 05:33 PM
Lev's Avatar
Lev
Default RE: Noticed my headlights dim!!
I've never noticed that before. Do they put out enough light to illuminate the road? I know you put an HID kit in, did you also get a relay harness? If this problem persists, and you don't have a relay harness, I recommend getting the harness. If that doesn't help it, put your halogens back in and see if they dim. If they do dim, something electrical might be wrong. If they don't dim, something might be wrong with your kit.
Old 02-29-2008 | 11:10 PM
2.0Mazda08's Avatar
i think its either the kit or the car it happens sometimes the holegens never ever did it though. No i do not have a relay on it but there is a fuse on the harness but no relay....
Old 03-01-2008 | 09:18 PM
Lev's Avatar
Lev
The relay takes power directly from the battery so that might help. I'm thinking it'd be more your kit because i went about two years without a harness and that never happened to me.
Old 03-01-2008 | 09:34 PM
2.0Mazda08's Avatar
yea i think its my kit...cheap *** kit...later on i will switch to 50w hid kit for now i guess i will leave this alone, unless a voltage stabalizer will help because i do not want to spend any more money on HID's.
Eggman84
03-28-2012 03:59 PM
GeorgeVergara
07-25-2011 07:22 PM
mloone01
09-07-2009 08:14 AM
awb101
11-30-2007 12:35 PM
sn0w1337
10-16-2007 10:00 AM
