Oily moily
#21
So I did a very dumb thing and put 6 quartz by accident. The oil level is about 1.5 centimeters above the "high" mark level. The car felt a little flooded when I drove it this morning. Is it wise to leave it alone or dump the oil? If I was to dump the oil, what would be the best way without dumping all the oil out?
#22
As for getting the oil out, you have two options:
- Open up the drain plug (preferably when the engine is cold) and drain a quart into a measuring cup, and then put the plug back in. This is going to get a bit messy.
- Use an oil extractor and suck the oil out via the dipstick tube (which is how I always change my oil, my drain plug has never been out of the engine).
#24
I've been using the "Big Pela 650" for the last 12 years; it can be seen here (near the bottom of the page): Quick, Easy & Clean Oil Changes with PELA Products
The Pela web site also has a link called "Where to buy - Contact us".
Amazon carries the Pela product line; they carry the Mityvac product line as well.
#26
Wow, buying an oil extractor is basically another oil change! I will dump some oil out over the weekend since it would be faster than waiting for the shipment and cheaper...
The oil filter is a spin-off. I wonder if it'll be slower draining it out this way but the circumference of the oil filter is bigger than the circumference of the oil plug... So it would make sense that oil will drain faster if drained from oil filter.
I did a little research regarding the consequences of having too much oil. Two things are very concerning...
1. Blowing out the engine seals
2. Car overheating
I really do notice that my car is sluggish. I'm guessing this is due to the crankshaft overworking through too much oil. Is there anything else I should be worried about?
What steps should I take in terms of driving the vehicle until I can get rid of the excess oil?
2. Car overheating
#27
2. Car overheating
2. Car overheating
Edit: think about the frequency of the splashing this way; you have four cylinders which means four times per rotation the crank throw impacts the oil and cuts through it leaving a trail of air. Most of the air escapes but some is trapped in the form of bubbles. At idle this happens nearly fifty times per second, at freeway speeds we're talking more like two-hundred times per second, and at high RPM we're talking more than four-hundred times per second.
#29
No, that wouldn't be wise at all; in fact, even starting the engine wouldn't be wise. Get the extra oil out of there before your next trip.
