pass. door handle vibrates
Old 12-23-2007 | 03:33 PM
esloyer's Avatar
Default pass. door handle vibrates
hey. when i play music, and there is some bass is the song, my outside door handle vibrates and rattles and it is very annoying from the inside. the music doesnt have to be really loud for this to happen either. anyone have any ideas or things i can try to fix it from vibrating so much?!
Old 12-23-2007 | 03:45 PM
dentinger's Avatar
Default RE: pass. door handle vibrates
hmm.... i have the same problem..
altho i can only hear mine from the outside, and it only happens on my passenger side...
Old 12-23-2007 | 04:03 PM
Could remove and pad it w/some silicone, perhaps?
Sure it's the door handle and not the ever annoying door drains?
Old 12-23-2007 | 04:24 PM
dentinger's Avatar
i was just planning on putting some dynomat in there when i finally get around to installing my speakers...
Old 12-23-2007 | 05:49 PM
esloyer's Avatar
well im not sure. when i go outside and hold the door handle it stops the vibrating, so i am pretty sure that it is the door handle, is there a screw of something that I can tighten?
Old 12-23-2007 | 07:26 PM
I've not had one apart... yet, but I'm sure there's at least one screw in there somewhere.
You may just have to do some exploratory surgery to find outthe what's, when's and where's of it all.
Before taking the door apart, as a test try putting a few little pieces of tape over the drain vents at the bottom of the door. Most complaints I've heard have to do with the plastic flap that's supposed to act as a one way valve under there. I don't use my stereo muchbut even I've heard them cause vibrations/noise.
Old 12-23-2007 | 07:57 PM
esloyer's Avatar
ok i will try that. anyone else have any ideas about the actual door handle?
mazpro00
12-19-2013 09:14 AM
RedGeminiPA
09-10-2013 12:10 PM
lsc91
03-11-2012 02:28 PM
wyciwug
10-17-2007 07:56 PM
Quick Reply: pass. door handle vibrates
