A-Pillar
Old 03-07-2011 | 05:48 PM
mzdaspd304's Avatar
Default A-Pillar
How do you remove the A-pillar? Any special tricks?
Old 03-08-2011 | 05:17 AM
icspots's Avatar
open door
grab rubber door trim along front edge of door frame and pull away from the frame
grab pillar and pull towards inside of car to release two tension clips (towards the bottom and in the middle)
slide the pillar towards the roof to release from the white pop clip at the top.
Viola
Old 03-09-2011 | 10:11 AM
Aubrey's Avatar
Uh... do you have airbags in them there A-pillars?
Old 03-09-2011 | 01:31 PM
icspots's Avatar
I do. the airbags are attached to the actual pillar of the car, not the plastic trim piece on the inside. You won't be able to activate the airbag by removing the trim. If you are concerned by it then you can always disconnect the battery, and step on the brake for a minute to drain the capacitors.
cagey63
11-13-2011 05:03 PM
kd623
05-13-2011 12:56 PM
popadic2007
10-11-2010 12:29 PM
Yorky
03-24-2008 01:22 PM
mazda3jay
10-22-2006 02:41 PM
Quick Reply: A-Pillar
