Please help with my new Mazda 3 DPF issue :(
Hi All,
Hoping someone can help me.. With my first Mazda, it is a Mazda 3 1.6 HDI 2006.
I bought my first Mazda 3 and recently found out it has DPF issues ( few days). I did a lot of reading on the internet and found the car is a Focus pretty much and got some software called Ford-Scan.
The problem is when driving the car loses a lot of power and struggles to go. I get a lot of error codes (listed below.) we have tried a forced regen which was successful but has made no difference and fault is still there.
Code: P2584 - Fuel Additive Control Module MIL Request
Code: P2458 - Diesel Particulate Filter Regeneration Duration
Code: P242F - Diesel Particulate Filter Restriction - Ash Accumulation
Code: P2455 - Particulate Matter Trap Differential Pressure Sensor Circuit High
Code: P1927 - Fuel Additive Level Too Low/Empty
Code: P1932 - Fuel Additive Level Low
Code: P1922 - Fuel Additive Level Circuit
Anyone got any ideas? I have been searching the forums and it seems I may have to put some fluid in? can anyone please advise what need to do? My partner can do the work, he is just used to doing stuff with VW/Skoda and has no experience with DPF so it is up to me to find out.
Thanks, all help will be appreciated
Jennie X
Jennie X
You need pat fluid do not use add blue
d patfu
Hi All,
You need pat fluid witch go in a small tank next to your flue tank but sounds like you need a regen too I have same problem I put pat fluid in but my light keeps coming back on do not use adblue
Jennie X
Jennie X
carl69
04-05-2019 04:29 AM
