Red Key Indicator with Exclamation
Old 08-23-2021 | 06:43 PM
msgfreebird's Avatar
Default Red Key Indicator with Exclamation
I bought my wife a new spare OEM FOB. We took it to be programed and now the car has a red key indicator but the push to start is green and the car runs although it seems to run a little rough. I have scoured Google with no luck on how to resolve the issue. Anyone here ever have this issue?
Old 08-24-2021 | 07:34 AM
Take it back to whoever programmed it. Or get it scanned for fault codes.
Old 08-24-2021 | 06:23 PM
Mazdaon's Avatar
If the key you've had purchase was exactly the same model and with the same amount of buttons as the original, likely you bought a Chinese FOB, some programmers have difficult finishing programming and the car trigger an alarm. Car would run and start normal.
Check with a scanner for DTC's, DTC B13D3:4A-8A is what you expect to see for this issue.
Go back to to the locksmith and show your problem, maybe he got another kind of programmer.
BTW, your car running rough it's got nothing to do with this.
Old 05-13-2022 | 10:47 PM
msspag's Avatar
Default red key indicator with exclamation
red key ind
I am having the same problem. A Chinese FOB! Is the best remedy getting the OEM FOB or can the Chinese FOB be programmed?
Ricky Souch
06-24-2023 07:44 AM
CoopMA
03-27-2021 03:03 AM
Gail Hellewell
11-05-2018 05:39 PM
tobias_funke
07-06-2012 01:30 PM
Ecnesse
08-08-2009 07:48 AM
