Removal of Cold Air Intake Filter
I'm looking at installing a cold air intake which I know requires taking the left front wheel off and part of the splash gaurd to remove the stock air box.I also noticed thatthe aftermarket cold air intake filteris positioned down near the wheel well when installed. Does anyone know ifI need to go through this same process when removing theair filter for cleaningor can it be reached without removing the wheel and splash guard? This will utlimately help me decide whether to go with the short ram or full cold air intake.
RE: Removal of Cold Air Intake Filter
you can take the bumper off.
trust me, its WAY easier.
11 screws along the underside of the bumper, 1 screw on each side of the bumper(on the inside, where the bumper meets the fender), and 2 screws where you grill is.
its not as hard as it looks. i can take my bumper off in about 10 minutes now.
Do you put the front end on jack stands or do you just crawl under and unscrew the bumper? Let me get this right. You have to take off the front bumper everytime you want to get to the air filter?
I put the K&N short ram intake on my mazda3 recently but i havent had to clean it yet.
you could potentially take the short ram intake out from the top, just remove the intake from the throttle body. Do you know how often you should clean your intake???
MS recommends 20K for my CAI between cleanings, but an SRI lives in the engine compartment so it may be more often. I'm not sure about that one though.
According to the dyno sheets I've seen, usually 2-3hp, but w/o any other mods (i.e. header and/or exhaust system) the gain would be reduced anyway. If the engine can't exhale, it can't inhale as much either.
DjSlickSVG
01-27-2014 11:29 PM
zakkzander
Intake, Headers and Exhaust
06-24-2013 12:58 PM
linuxguy0481
04-14-2012 05:25 PM
