Replaced stock exhaust tip.
Old 06-02-2007 | 11:36 AM
JimsMazda3's Avatar
Default Replaced stock exhaust tip.
Didn't like the stock tip so I bought an 3.5" angle cut, double walled stainless tip, had it installed today.
Jim
[IMG]local://upfiles/10426/A6573C0386204F99AECE45F8389F0A15.jpg[/IMG]
[IMG]local://upfiles/10426/40D9838FDCB64021A111B2DF82CF6FA0.jpg[/IMG]
Old 06-02-2007 | 03:25 PM
sstlaure's Avatar
Default RE: Replaced stock exahust tip.
looks good...how did they attach it, a clamp? the tip is stainless and the stock exhaust isn't.
Old 06-02-2007 | 06:05 PM
JimsMazda3's Avatar
ORIGINAL: sstlaure
It's welded on. The shop cut the stock tip off just after the spot welds and welded this one on.
Jim
Old 06-02-2007 | 06:11 PM
[font=californainfb]Good Job!! [sm=bling.gif]
Old 06-02-2007 | 08:15 PM
MikeMzda3's Avatar
im glad you posted this, the tip looks real nice - ive been wanting to swap mine out aswell... my only question is how did they attach it? i know it was welded...but every tip i look at thats 3.5says it has an inletof more than the 2 inches of the stock 3 exhaust.
Old 06-02-2007 | 09:08 PM
JimsMazda3's Avatar
ORIGINAL: MikeMzda3
The inlet is 2.25" and I measured the stock pipe at a hair over 2 1/8" at the tip so it's almost a dead on fit. The veryend of the stainless tip's 2.25" inletis also tapered in some so it's slightly smaller than 2.25", it fit almost perfectly. You can get a 3.5" or a 4" tip, I chose the 3.5" tip...
Jim
http://cgi.ebay.com/STAINLESS-STEELT...QQcmdZViewItem
Old 06-02-2007 | 09:38 PM
MikeMzda3's Avatar
awesome. thanks man
Old 06-03-2007 | 01:19 AM
Lupae3s's Avatar
the tip you installed looks nice and aggresive. im aware you did not make any adjustments to the stock exhaust piping, but did the alernate exhaust tip modify the sound of the car at all?
Old 06-03-2007 | 11:09 AM
JimsMazda3's Avatar
ORIGINAL: Lupae3s
No, no sound change at all. If you look at the tip, it's really 2.25" most of the way, then it's beveled out to 3.5". So, it's really not any bigger for the sound waves to bounce around in and make more sound. That how it's a double walled tip. From looking at it when I got it, it's a 2.25" piece of pipe, they bevel it our at the end to make it 3.5", then fold it over back towards the inlet section. When you look at it from it's back or the inlet pipe, there's actually an open space between the inner pipe and the outer pipe. This spacing will allow the outer part of the tip not to turn yellow as stainless does when it gets' hot because it's not in direct contact with the exhaust gasses so it won't heat up and turn yellow. Also, you can't see the open space once it's installed because the tip is under the bumper, you only see the tip sticking out. The only way to see it would be to crawl under the car and then you could see it. Hope all this makes sense, if not, I'll shoot a pic so you can see what I'm talking about. Don't worry, it's a nice tip!
Jim
Old 06-08-2007 | 09:48 AM
MikeMzda3's Avatar
does anyone think a 4 inch exhaust tip is too big for the 3? I don't want a coffee can but...trying to find a suitable aftermarket tip has proven harder than expected.
the one im looking at is :
http://cgi.ebay.com/ebaymotors/MAGNA...spagenameZWDVW
leme know if you think its guna be too huge.
