Right Turn Signal
Old 07-27-2008 | 12:38 PM
luna48's Avatar
Default Right Turn Signal
My right turn signal won't turn off after making right turn, I tried it a couple of times making sure it was a 90 degree turn. The left turn signal works fine. I have 05 model. Does anyone know what the problem is and how much it might cost to fix?
Old 07-27-2008 | 02:51 PM
Default RE: Right Turn Signal
The canceler devise is part of the switch assem... $75??
Old 07-28-2008 | 12:11 PM
MikeHTally's Avatar
Back when I had my '66 LeMans, the turn signal canceller broke. It's a tab inside the steering column that just kicks the lever back to the neutral position. Are they still made that way? Might be harder to get to than that one, and you'll be contending with the airbag system. Maybe the column comes apart below the hub. Make sure you disconnect the battery and leave it alone for a few minutes.
MikeHTally's Avatar
Wow, a whole paragraph, an' it didn't kick me out.
Eastcoastmod
04-17-2015 01:48 PM
ddavis43224
03-16-2011 09:55 PM
Sean
07-20-2007 06:40 PM
Alucard
08-02-2006 05:23 AM
rshal
06-10-2005 10:48 PM
Quick Reply: Right Turn Signal
