Rivet come off in turbo..
Old 11-22-2021 | 01:35 PM
Benedmonds's Avatar
Default Rivet come off in turbo..
I have a 2015 Mazda 3, 2.2 diesel. 60k miles. Half the warning lights have come on dash is like a Christmas tree. It drives ok until you push it and obviously some issue with the turbo.
Took it to Mazda who charged me £75 to tell me it was an issue with the turbo and was £300 to inspect the problem.
I therefore took it to a local independent, he says he had a few Mazda do this and there is a missing rivet. Worst case the rivet ends up in the engine it can lead to needing an engine rebuild. Most likely scenario is a new turbo. Quoting around the £3k mark.. I have had a Google and can't see this as a regular problem, seems odd that a local garage would have seen 3? Also not sure I want to spend £3k + on a car worth £6,500 if it was in good condition..
Old 04-19-2022 | 01:44 PM
ColPanther's Avatar
Hi there,
I have had a similar problem with my cx-5 (2016). I took it to a Mazda dealer for a diagnostics and they told me the turbo rivet has come off and a new turbo is required. This is a very expensive repair from a Mazda dealer (£3000 +) They also recommended a carbon clean. What happened to your Mazda? Did you end up getting it fixed?
Old 04-19-2022 | 02:35 PM
Benedmonds's Avatar
Originally Posted by ColPanther
Hi there,
I had a local independent garage fit a reconditioned turbo. £2,250, It is still running..
Old 04-19-2022 | 02:39 PM
ColPanther's Avatar
Thanks for the update
wayne84
07-27-2022 10:48 AM
elfrider
09-02-2020 06:55 AM
AloeVera
10-22-2015 03:57 PM
garyd
04-25-2015 11:10 AM
Rice Burner
03-24-2008 01:07 PM
