sensors
sensors
Just looking for some help here.
i have my mazda3 and a have some problem whit it.
the abs light goes on and the brake light to and my speedo meter does not work.
i have already scanned it and the computer says it was the speed sensor poblem.
i ordered it and instal it reset etc.. and the problem persist
my question is. is the ABS speed sensor the same as the transmation speed sensor??
because each wheel has a ABS speed sensor.
or is the gear in the transmation not giving signal??
RE: sensors
Isn't your 3 still under warranty? Sounds like something that you should not be having to deal with if warranty still applies. Your speed sensor for the speedo is in the tranmission by the way. Does not use the ABS wheel sensors in your application.
RE: sensors
Hey thanks for the help babyhuey.
by the way i had to change my transmition becuase someting in the diferantial assembly was broken. (this is a demage car not new)
and i am done now..
another question is what kind of transmisionoil do you recommend me to use for my transmition?
can i use dextron III ???
thanks again for your help guy's
see ya..
and i am done now..
see ya..
