Shift Solenoid B (electrical error)
Old 01-27-2020 | 11:18 AM
Kylie Gleason's Avatar
Default Shift Solenoid B (electrical error)
Looking for some advice on what could be wrong with my car. I’ve had it hooked up to a computer the code was shift solenoid B malfunction (electrical error) P0758. After the solenoids were replaced, I drove it the next day and the AT light kicked back on and my car started kicking when It would switch gears and wouldn’t go into third. Same problem before I changed the solenoids. Computer is reading off the same code. Any idea? Sometimes I can drive it if I rev slowly but when I make stops it likes to mess up. 2010 Mazda 3 2.5L
Old 01-28-2020 | 06:25 AM
DTC P0758:00 Shift solenoid B electrical malfunction
DETECTION CONDITION •
The TCM detects that output voltage to the shift solenoid B is stuck at 0 V or B+ when the solenoid valve operates according to TCM calculation.
Diagnostic support note
• The MIL illuminates if the TCM detects the above malfunction condition during the first drive cycle.
• The AT warning light illuminates if the TCM detects the above malfunction condition during the first drive cycle.
• PENDING CODE is available.
• FREEZE FRAME DATA is available.
• The DTC is stored in the TCM memory.
POSSIBLE CAUSE •
Coupler component connector or terminal malfunction
• Short to power supply in wiring harness between shift solenoid B terminal B and TCM terminal AJ
• Short to GND in wiring harness between shift solenoid B terminal B and TCM terminal AJ
• Shift solenoid B malfunction
• TCM connector or terminal malfunction
• Open circuit in wiring harness between shift solenoid B terminal B and TCM terminal AJ
• TCM malfunction
67Camaro
12-29-2023 06:28 PM
mpv2kowner
12-04-2021 07:21 PM
MazdaSebas
06-01-2018 05:13 PM
Shaunt
04-27-2015 06:27 PM
katocal
04-04-2015 12:38 AM
