Shift solenoid fault code in manual transmission Mazda 3 1.6L
Old 05-28-2018 | 05:27 AM
MazdaSebas's Avatar
Default Shift solenoid fault code in manual transmission Mazda 3 1.6L
Hi,
I just became the owner of a Mazda 3 2004 1.6L petrol engine. The drives great and I have no problems with the car. The only thing is that the check engine light is on. I connected the computer to the car and it turns out there is an error P0768, P0773 and P0763 which points to shift solenoid D, E and C. The only thing is that I thought there aren't any shift solenoids in the car because it is a manual transmission.
Does anyone know why these faults could occur and better yet how to repair it?
Kind regards,
Sebastian
Old 05-29-2018 | 03:10 AM
MazdaSebas's Avatar
Whist investigating I also found an error code regarding the internal temperature sensor of the ECU and an error code that shows there was a low voltage from the battery. My idea is that it might be a computer or cable problem. I will start checking the wiring. Anybody else that had trouble with different fault codes that are not consistent with each other?
Old 05-30-2018 | 04:49 AM
Clear the codes. go for a drive & see if any codes come back.
Old 05-30-2018 | 09:36 AM
MazdaSebas's Avatar
Thank you for your reply. I cleared the codes, went for a drive and checked them again. Stil the same codes. Also, from time to time, my interior lights won't switch on when I switch on my headlights. When I try a couple of more times it works again. Because I am changing the two lights on the back panel of the airco control I found that, when I remove the light of the cigarette depository, the interior lights start flashing multiple times per second and a small beek tone with it. When I put the light back in it is usually gone but sometimes I have to wiggle it a bit.
Seems to me like it is a ground issue. What do you guys think.
Old 05-30-2018 | 05:15 PM
MazdaSebas's Avatar
In addition to that it seems that the lights of the radio dim as soon as I switch on the headlight. As soon as I switch them of the radio is brighter again. Another thing is that when I start the car and read the fault codes the P2088 is there. When I erase them with a running engine that fault code does not come back. It comes back at the moment the car starts again.
Old 06-01-2018 | 05:14 AM
What condition is the battery in? What's the output of the alternator with & without load?
Old 06-01-2018 | 05:13 PM
MazdaSebas's Avatar
Just measured the voltages at the battery.
car off: 12,0 Volts
car on stationary: 13,7 Volts
car on 2500 rpm: 13,3 Volts
jav773
06-19-2011 03:20 PM
jav773
06-11-2011 10:40 PM
mlapaz@comcast.net
04-15-2011 08:16 PM
cuyuni
03-20-2006 04:30 AM
