Simple Green cleaner - for your car?
Old 05-15-2008 | 09:04 PM
UrbanmanUSA's Avatar
Default RE: Simple Green cleaner - for your car?
Given tar is a hydrocarbon, anything completely water based will have little effectiveness. Simple Green should work on tar, try it nicely diluted first.A pointabout Simple Green is it is highly alkaline (acidic), so wherever you use it, you want to make sure it is THOROUGHLY rinsed off. If you leave SG on there, the acid will continue ... being acid.
WhatI like about simple green versus the claybar ... with the clay bar, you are using friction. The bar itself may be non abrasive, but you are rubbing. There is some friction at play, you are forcing/pulling the tar off. With SG, you are chemically disintegrating the tar, changing the tar molecularlyso it releases, then rinsing, the process is completely non abrasive. As long as you have confidence the SG will not damage the paint finish (diluted in accordance with the instructions, then rinsed thoroughly within a short time frame, it should not), it seems a better path to me.
wrknonit
05-31-2012 03:45 PM
ryanjeanes
07-05-2011 04:36 PM
Badass
09-17-2010 10:22 PM
Tekron
10-30-2009 02:52 AM
tazman
04-19-2006 11:04 PM
