SKUNK 2 SPRINGS ( WHAT DO YOU THINK ? )
RE: SKUNK 2 SPRINGS ( WHAT DO YOU THINK ? )
ORIGINAL: VanSin23
There is a local performane shop around here and he swears by the skunk 2 springs. He has put them on his cars in the past and he said they ride very well. My only concern is that they are a 2" drop and usually anything over 1.3" will affect tire wear more than under that 1.3". I asked him about a camber kit and he said tht it said on his computer that they did not need them. I would not put 2" springs on my car w/o a camber kit. I am looking at the Eibach pro-kit or Tech.
ORIGINAL: VanSin23
Did you have the camber adjusted in the front when you had it aligned after the drop? I think there are adjustments for the front but a kit is needed for the back.
Also, the quick wear was on my Summer tires which are very soft and sticky. I just started my 3rd winter on my
winter-only tires and the wear is much less conspicuous.
Did you have the alignment shop adjust the front camber or is there not one and an aftermarket kit was needed? I kow the back has to have one installed. You do it yourself? How hard if so. Thanks.
lapinkulta
12-24-2005 05:22 AM
