Starting problem
Old 06-03-2019 | 09:54 AM
Belairbarca's Avatar
Default Starting problem
Car starts but engine shuts off either after 15 seconds, or immediately if the gas pedal is applied. And once car shuts off, it will not restart for several hours. Initial problem was that the engine shut off while driving; was able to safely pull off to the side, but then car would not restart. Currently, when key is in the ignition in the on position, the "check engine" and "power steering malfunction" light remain on. The "security indicator light" remains off. When key turned to start and engine is running, only the "check engine" remain on.
The following codes were pulled:
P0101 - MASS airflow sensor (was pulled and sprayed with electronic cleaner, no change)
P1260 - Immobilizer system
U0442 - Power Steering Pressure
2012 Mazda 3i Skyactive w/ 170K miles
Thanks in advance.
ControlG
01-15-2007 11:51 AM
GRHoward1937
11-02-2006 01:16 AM
Tbird
08-25-2006 03:50 PM
bar17
05-17-2006 11:56 PM
sabanab35
08-29-2005 08:59 AM
Quick Reply: Starting problem
