Sunroof?
Sunroof?
I wanted to know is it better to have your mazda 3 with or with out a sunroof? I just got a 05 black mica mazda 3 a few months ago, but did not have a sunroof already install. I would like to have one but I wanted to know is it worth getting or should I do some other mod with the money?
RE: Sunroof?
You'll have to install an aftermarket sunroof. Best ask around about places that install them in your area. Are you sure, you want someone cut up the roof and headliner? If you do, check to make sure the kit you have installed has water drains in each corner.
RE: Sunroof?
ORIGINAL: gtxtreme
RE: Sunroof?
I used to work for a company that made sunroofs and one thing to bear in mind is that they are NOT designed to be sealed to prevent water from getting in. They know water will get in and around the sunroof. Any decent sunroof maker knows this and has the drains that go down your a-pillar. If they don't have the drains, DON'T buy the sunroof.
I am in the market for a new car and would like a sunroof. If I can get one, fine, but if it is not a factory sunroof, I wouldn't pay the expense to have one installed.
niterider40
04-21-2015 12:47 AM
