synthetic oil
RE: synthetic oil
Ive been using castrol syntec 5w-20 since i got the car at 21k miles and the previous owner used all sytec as well. However, my car is reaching 60k miles (damn 04 3i 2.0L and the previous owner driving to cali and back from St. Louis like 3 times) and ive been leaning more towards the castrol syntec blend 5-20. I want to throw in some hi milage to recondition the seals and what not but im probably having my heads ported and polished soon with a bored out Throttle body and while im helping with the headwork ill probably starting replacing seals anyway. but ill let you guys know how that works
RE: synthetic oil
There are those who believe that pure synthetic is great in engineering tests, but that not having some "real" oil as part of the make up somehow deprives the lubricant of something which should be there.
I have known several mechanics over the years, none of them used synthetic oil in their personal cars. They were more adamant about getting the oil and filter changed a little more quickly than manufacturers recommendations, than they were all hung up on brand or synthetic. One guy I knew changed it as soon as he saw any change in color on the dipstick, since he saiddiscoloration was dirt, and he wanted dirt out of his engine.
Semi synthetic oil could be worth considering ... maybe the best of all worlds?
RE: synthetic oil
ORIGINAL: RedlineRN
I'm not do for an oil change yet in my MS3-and she's off road till april anyways...but I plan to run synthetic in her. I ran mobile 1 in my 2004 Mazda3. You can not run synthetic in the RX8.
RE: synthetic oil
ORIGINAL: UrbanmanUSA
If you do some research, you will find that there are three groups of synthetics.Most synthetics are really purified/modified petrolium oil that originated in the ground and are Group 3 Synthetics. Mobil 1, Royal Purple and AMSoilcome from the lab and are Group 4 synthetics. I'm not positive, but I think all of them use PAOs for the base oil (I know this is true for Mobil 1). Redline is the only Group 5 synthetic that I know of and it use Poly Esters (?) as the base. Group 5 is generally the category for additives. Also, the synthetics use less additives because they can build the properties into the base products. I'm no expert, I have just some some reading. The Group 3 oils are only considered to be synthetic because Castrol won in court when Mobil 1 sued them. I generally use Mobil 1 simply because it is easy to get andthe price isn't horrible. AMSoil, Royal Purple and Redline are more difficult to obtain.
RE: synthetic oil
ORIGINAL: dentinger
okay, im due for my first oil change sometime soon (im at 4500kms)...
what are the advantages of synthetic oil over plain old oil??
i drive a mazda 3 with the 2.0 engine, btw
(2) There is less friction with synthetics so in theory the engine should last longer, but if you are not planning to keep the car beyond 100,000 miles it shouldn't be a factor for you.
(3) Because it hold up better to heat, it provides some added protection if you have a cooling system issue.There is a guy on one of the Toyota boards that I'm on that tried to toast his motor before he installed the new one. He pulled the drain plug anddrained all the oil. He drove it over a 100 miles with the remaining Mobil 1 and the engine was still running fine. He won't run anything else.
(4) You might see a slight increase in gas mileage.
(5) In the cars that I have switched to either synthetic or blend I have noticed the engines felt smoother and quieter.
(7) Synthetics generally have better detergent properties so they keep your engine cleaner. This is part of the reason that high mileage engines develop leak when switched. The synthetic oil cleans out the build-ups that were covering leaks.
If you change your oil on a regular basis, you may never notice a significant differenceand it does cost a bit more.
Iam currently planning to run Mobil 1 in my new 89 4Runner engine once it gets put together and broken in and the MS3 will either have the dealer synthetic (Quaker State) or the Redline they offer in the parts department. The Redline is overkill for most cars, but since it will be going through the turbo it might be a good investment for me.
RE: synthetic oil
im gonna end this stupid argument once and for all.
u guys should realize. that using full synthetic is CHEAPER than regular oil. not only that, it will make ur engine last ALOT longer. if nothing else breaks, 200k+miles isnt unheard of for a car on Mobil1, etc.
cheaper, why? because regular oil u shud change ever 3500 miles. with my Mobil1 5W-30, i do a change every 7500. thats double the mileage, and slightly less than double the cost. (i get 5 quarts for $23 @ walmart)
if u dont run synthetic ur being retarded to ur wallet, and ur car.
RE: synthetic oil
ORIGINAL: blackdiamond
HAHA YEA RIGHT. thats total bull**** IMO.
