transmission error code all at once
Old 04-02-2015 | 02:51 PM
katocal's Avatar
Default transmission error code all at once
Hi, all at once i received the following error codes related to transmission:
P0753 Shift Solenoid 'A' Electrical
P0758 Shift Solenoid 'B' Electrical
P0763 Shift Solenoid 'C' Electrical
P0768 Shift Solenoid ‘D' Electrical
P0773 Shift Solenoid 'E' Electrical
can all the selenoid go bad all at once or is it posslible a different problem. any ideas before i remove the transmission pan will be appreciated.
Thx in advance
Old 04-03-2015 | 04:42 AM
What year & series is your car? How many km's/miles?
I've seen this before, get a full flush done & filter change ( if fitted). Get the codes cleared and go from there.
Old 04-03-2015 | 06:25 PM
katocal's Avatar
it's 2008 mazda 3 138K. with a replaced transmission that is 50K. it was running w/o problem for about 3 month then parked for 3 month and this happened right after i turned it on after 3 month garage parked. i'm in the Michigan with extreme cold conditions I'll try the transmission oil and filter flush within a day or two, but wandering why a flush would get rid of these codes.
Old 04-03-2015 | 06:59 PM
hixx's Avatar
Check the main connector on the trans as well as all the fuses.
Old 04-03-2015 | 07:06 PM
katocal's Avatar
makes sense, will do.
Old 04-04-2015 | 12:38 AM
Dirt & crap can get stuck in the solenoids.
hzleygirl
11-02-2013 09:20 AM
chursy
09-09-2005 12:50 AM
sebfas
07-16-2005 12:47 PM
prostarthunder
04-09-2005 05:37 PM
beavertail
02-02-2005 04:59 PM
