Vibration on the Front Right
Old 06-11-2011 | 07:05 AM
TampaDave's Avatar
Default Vibration on the Front Right
My Daughter's car has 104K miles. So I decided to give it a drive to look for needed maintenance issues. One thing I found was a vibration in the right Front tire area. It only happens on acceleration between first and second gear. ( it is an auto transmission, but I see the dash numbers changing)
Any ideas where I can start the trouble shooting process. ??
Old 06-12-2011 | 01:47 PM
Tracker's Avatar
i say axles (mine does the same) but id have the wheel balance checked first just to be safe
Old 06-13-2011 | 11:09 AM
TampaDave's Avatar
The car seems to vibrate on right turn only. Tires are Brand New. Could it be a CV Joint going bad, if so how would I check?
Old 06-13-2011 | 02:23 PM
Tracker's Avatar
if car makes a clicking sound when turning left then its your right axle and opposite for left turns. Lift up the car and grab the axle, if it has too much play then its bad
Old 06-16-2011 | 08:10 AM
icspots's Avatar
You may also want to check the right motor mount.
menash2
09-11-2012 04:41 AM
ggmalott
08-24-2012 07:20 AM
mamesteco
01-25-2012 10:43 AM
vlstellato
07-20-2009 10:23 AM
apbbnbanb_07
06-11-2009 05:36 PM
Quick Reply: Vibration on the Front Right
