Will a 2005 CD changer work in a 2004?
Old 05-01-2007 | 01:10 AM
xpac's Avatar
Default Will a 2005 CD changer work in a 2004?
As the title states, I have an 04' sedan whose CD changer no longer works (the standard Mazda 3 6 disc in dash CD changer). I found one from a junked 05' on ebay, and it states that this part will fit an 05'. My brother has an 05' and from the outside (he won't let me take his audio console out to compare with mine), it doesn't appear to be any different, however I know that doesn't mean anything. Can somebody with some expertise tell me if they are different, and save me from wasting my money? FYI I'm not planning on keeping this car for more than another year (which is why I'm looking for a CHEAP replacement rather than something new), but in the meantime I would like to be able to listen to CD's until I get rid of the car.
Old 05-01-2007 | 01:19 AM
icspots's Avatar
Default RE: Will a 2005 CD changer work in a 2004?
Assuming you're in the US then I can say, yes, the '05 changer will work in your '04. Actually you get a bit of an "upgrade" since the '05 one should also have a "SAT" button on it just in case you want to add sirius to the car. The problem with compatibility comes in the '06 HU where they separated the LCD wiring harness from the main HU wiring harness so there are two plugs intsead of one. That being said I'm not sure if you could just use the changer portion of a 2006 model and have it work vs. using the entire HU from a '06 and it not working.
In any case I digress. Yes it will work. Oh and you're brother's a pansy (j/k).... you can pull the HU in less than 5 minutes with just your fingers and a phillips head screwdriver.
Old 05-01-2007 | 01:58 AM
xpac's Avatar
Hey thanks a bunch! And yeah, I tried telling him that taking it out was nothing, I got mine out in about 5 minutes and I'm far from an expert. Thanks again!
dsmx
01-26-2009 11:42 PM
michael91077
04-05-2006 09:43 PM
the_gray_mazda6
12-27-2005 12:56 PM
jrflyboyVP2
12-11-2005 02:07 AM
slimwhit33
07-21-2005 05:48 AM
Quick Reply: Will a 2005 CD changer work in a 2004?
