Will driving w/o gas cap damage my car?
The fuel system is pressurized. The gas cap is integral part of that pressurization stability. Sorry to say anyone saying it's OK to allow fuel injection to operate unpressurized is incorrect. Replace the cap with a Mazda OEM pressure sensitive cap.
The fuel system is pressurized. The gas cap is integral part of that pressurization stability. here Sorry to say anyone saying it's OK to allow fuel injection to operate unpressurized is incorrect. Replace the cap with a Mazda OEM pressure sensitive cap. https://www.viberate.com/
The gas cap is part of the emission system. Not having the gas cap is actually more a Federal regulation because it causes air and ground pollution.
In some cases, you can read from DIY sourced information that it will cause you to lose MPG but that is from the fuel evaporating.
On the flip side if a gas cap was so important then there litterly would be vehcles breaking down every day every where and they aren't.
Not having a gas cap itself should not cause anything except a check engine light a DTC(S) and your monitors to be in fault until the cap is replaced wither missing or damaged or not sealing properly.
Cant believe some DIY members on forum for empirical information. Do your research if you want the straight facts and not someone guessing?
READ THIS THREAD:
Car Repair Advice Forum= at your own risk - Mazda Forum - Mazda Enthusiast Forums
Just an FYI your original response is in the member history as well any member that sets watch this thread in thier setting will get an alert and the original quote. So editing your response at any time and espcially after this long is sorta of well... I would just say make sure you like what you post and not wait so long to edit if you don't in the future. Also it might be helpful to fill in the reason why you edited it? But I seldom do that.
