window auto wind problem
Old 02-19-2010 | 08:20 AM
davyrob_mazda3's Avatar
Default window auto wind problem
before i go back to the garage and get them to look at the problem i thought i'd ask some advice on here
for some reason the one touch auto opening on the driver window has stopped workin, the button still allows the window to go up and down but not by one touch.
It worked before and has now stopped. Is this a reset problem or is the switch knackered
If so is it easy to fix yourself?
cheers
Old 02-20-2010 | 01:37 PM
Tracker's Avatar
ur gonna need an electrical diagram to find out where the problem may start
Old 02-20-2010 | 02:09 PM
kingmansnyper's Avatar
Default Fix is easy
All you need to do is pull both windows up,
then go to the passenger seat and roll the window all the way down and then up once in the up position without letting it go hold the button up for about 3 seconds (until there is a beep)
do the same with the driver seat and once you have finished with the driver seat window the button should be programed, you'll need to do this if you change the battery too.
HerrKaLeun
08-04-2013 08:34 PM
Traxx
02-04-2012 04:13 AM
MikeMzda3
07-07-2007 05:53 PM
mazda guy
03-09-2006 04:00 PM
MikeMzda3
02-07-2006 10:11 AM
Quick Reply: window auto wind problem
