wont start after gas fill-up
I have an `06 3 with the 2.0 and I am having an occasional problemstarting the carafterI fill up with gas. I can only get the car restarted by stepping on the gas pedal. Otherwise it just turns over and over. Any ideas on whats happening???
RE: wont start after gas fill-up
I also have an 06 Mazda 3 2.0 that had the same problem, wouldn't start after fill up, had to hold peddle to the floor to get it started.I took it to the dealer and they found it to be a faulty PURGE VALVE. If your purge valve is faultylike mine was it will be hard to start and will run rich causing bad idle and black smoke. Fault code was P0443.
