2006 Suspension
Old 05-03-2013 | 07:05 AM
smithc84's Avatar
Default 2006 Suspension
I'm considering buying a used M5 that has about 100k miles on it. It's in OK condition and I think I can get a good deal. When I drove it the suspension was terrible! The whole car seems to float and everything feels really loose. I do a lot of my own car work, so I was thinking that replacing the front struts and rear shocks should clear most of the issue up. Are there any major issues I'm not considering? I assumed I would get the aftermarket KYB hardware.
Old 05-03-2013 | 07:49 AM
The OE suspensions on these (especially the rear) are not very good. Aftermarket is the way to go.
With something with that many miles, if you can't get service history, i would change ALL of the fluids. Change the fan belts, clean the throttle body, MAF, change the PCV valve, clean the EGR valve.
You may have to change plugs, coils as well soon.
Old 05-03-2013 | 09:00 AM
smithc84's Avatar
Thanks for the quick response. I've read on these cars a bit, so I'm not walking in totally blind, but it's easy to assume the work to be done is easier than reality.
Old 05-04-2013 | 01:00 AM
slbenz's Avatar
I have a 2007 and replaced the struts and shocks myself. Wasn't to hard to do. I went with top line KYBs all around. I would also check the front and rear sway bar bushings. They will creak loudly when it is time for them to be replaced. Rears are very easy, but the front bushings were a pain.
Push2Drop
09-03-2011 03:44 PM
blue7starr
02-08-2011 09:20 PM
Seanace1
06-03-2010 10:21 PM
millyman
05-02-2005 09:39 PM
momazda44
04-11-2005 11:07 PM
Quick Reply: 2006 Suspension
