Cheap, temporary fix for idle/purge valve issue
Old 03-19-2011 | 10:50 AM
Hate/Love 5's Avatar
Smile Cheap, temporary fix for idle/purge valve issue
This may have been posted before, but I've been dealing with the bad throttle body/purge valve/BAD IDLE issue for about 2 years now. With the cruddy stealership here in Santa Fe, NM and all the talk about $$ spent with no real fixing of the issue on the 2.3's, I finally took some time to deal with it. I found a used Throtttle Body off a 2.3 "6i" with much better butterfly action than my original one for $100. This sovled my sticky TB, but not the poor idle. Traced it to the purge valve sticking open causing the dreaded o2 sensor rich condition, that little round valve next to the PCM in the engine bay. (When this valve sticks open, the car just sucks gas fumes from the tank and it's basicly like dumping fuel into your engine while it is trying to run normally) I removed the vacuum line from that valve to the intake manifold and capped both ends. MY 5 NOW RUNS LIKE NEW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!! AND NO ENGINE CHECK LIGHT!!!!!!
This may only be a temporary fix on my 07', but for now, it works like a dream!!!!!!!!!!!!!!!!!!!
Hope this helps anyone who has had nothing but trouble from their stealership on this issue and/or no real fix for it. Or like me, who's car was out of warranty by 3 days and the stealersihip wouldn't do squat-ola for me without major $$$$$$$$$$$$$$ being shelled out to them. They were so bad, they wouldn't even give me the repair procedures for the purge valve issue without me paying for the whole fix. F them and their bad purge valve/ throttle body design!!!!!!!!!!!!!!
Old 03-22-2011 | 09:41 PM
icspots's Avatar
Not sure on the cost of the part, but you could always just buy the PCV and replace it yourself. Check with onlinemazdaparts and mazdastuff and see what kind of prices you can get for the part itself.
Old 03-23-2011 | 09:00 PM
It's not the PCV, that line goes to the air tube between the air box and the throttle body
This is the Evaporative Emissions Purge Valve, goes between the fuel tank and the intake manifold
THE PART IS $110 FROM MY LOCAL STEALERSHIP AND IS NOT A PART THAT IS LISTED ONLINE ANYWHERE! It's one of those scham parts, underdiesigned for it's use and breaks all the time
drturnip
10-01-2012 09:27 AM
bluntablo
01-25-2012 11:08 AM
allhan
09-26-2008 05:07 PM
nhlatl
02-22-2008 05:43 PM
Quick Reply: Cheap, temporary fix for idle/purge valve issue
