DIY 3rd transponder key not working...
Old 03-18-2020 | 08:06 PM
dbelcourt's Avatar
Question DIY 3rd transponder key not working...
Hi,
Picked up a set of those flip key/FOB blanks off the auction site. I only had one key so I took the car to local place that did key programming. They cut both keys but only managed to program the transponder and FOB of one of the two. Tech said the other key was bad.
I tried to follow the outlined procedure of insert 1, ON for 5 seconds, quickly insert 2,ON for 5 second, quickly insert 3(new), turn ON and the key dash light is supposed to stop flashing. Mine continues to rapid flash for about a minute then goes back into the engine off occasional quick flash. I tried several times, sometimes only waiting a second or so. Of course it won't allow the car to crank and turning the key simply sends the key dash light into the quick flash mode.
Has anyone else gotten a bad after market transponder key?
Anything else I should try before buying a whole new key again?
Is there such a thing as a maximum number of keys or getting a locksmith to program the two keys with the OBD tool wipes out all previous keys?
Sounds like I just got a bad key...
DB
Old 03-21-2020 | 12:19 AM
Most Mazda's have a limit of 8 programmed keys.
However, when you programme a new key, all old keys not physically present at time of adding a new key are automatically deleted. Programming keys requires a specific in code & out code from Mazda.
Old 03-21-2020 | 06:31 PM
dbelcourt's Avatar
Thanks... I read in a couple a places that if one has 2 working keys they can add a third (or more) without the dealer or locksmith. Are you saying that the DIY procedure doesn't work with an 2009 mazda 5?
Old 03-22-2020 | 04:56 AM
I don't know anything about adding a third key that easily. Also, with all my Mazda experience, they don't sell the Mazda 5 in my market.
Old 05-06-2020 | 02:22 PM
icspots's Avatar
You’re correct, as long as you have two working keys you can use the method you mentioned to program additional, up to 8. It can also be done with the dealer plugging in with a computer.
Sounds like either the transponder chip in the key is bad, or is missing.
Old 05-09-2020 | 10:21 AM
pkthomas's Avatar
Look into Forscan. It is a software you can download. There is an option for programming keys in it. Forscan is free but you will need to buy an OBDII adaptor and need a laptop or a PC close to the car.
Old 03-06-2021 | 02:13 PM
SJM-MK's Avatar
Can Forscan be used for programming a second transponder chip if you only have one key that works with the immobiliser?
slydog1010
01-21-2017 03:00 AM
scorpion48
04-28-2011 02:43 PM
RWBitters
08-19-2010 06:56 AM
LPG
01-29-2009 10:36 PM
RetroActv
09-15-2007 09:31 PM
Quick Reply: DIY 3rd transponder key not working...
