Grinding Noise in Front
Old 10-29-2012 | 01:50 PM
jonijesjusja's Avatar
Default Grinding Noise in Front
It's mostly noticeable when going over a bump and turning slow. What do I need to check to isolate this problem?
Old 11-01-2012 | 02:24 PM
This is not much of a forum, anyone actually replies to posts here?
Old 11-01-2012 | 05:37 PM
tanprotege's Avatar
including this one I have 597 posts and most of them are replies. Hey you get what you pay for. Except here, you get more than that!
Grinding noise from the front over bumps and when turning. From the left or from the right? Jack it up, secure it with jack stands and inspect the suspension, steering, CV joints. Are all rubber parts in place and in good condition? Grab the wheel 6 and 12 o'clock and try to push it in and out. Any wiggles? Grab it 3 and 9 o'clock and rock it. it should give some but maybe it makes a knock and you can feel play. There shouldn't be play.
My educated guess: the CV joints are bad.
Old 11-01-2012 | 06:29 PM
Year? Mileage? (Rookies)
Wheel Bearings? Brakes?
Old 11-01-2012 | 11:00 PM
nicothehut's Avatar
I second Wheel Bearing as being the problem.
Old 11-23-2012 | 04:51 PM
09 with 65K miles
I replaced the rotors and brake pads a few months back
how do i check if it's the wheel bearings?
Old 11-23-2012 | 04:53 PM
Rubber parts look good, no wiggles and play. You still think CV joints?
Old 11-23-2012 | 06:42 PM
Originally Posted by jonijesjusja
09 with 65K miles
But did you replace the hold down hardware?
A few years ago when i had my brakes services, he took it for a test drive and the one front side was making a noise. He had to re-bend the thin hardware to make noise go away. I bought new hardware this time and hardware was falling apart.
Old 11-24-2012 | 06:29 PM
tanprotege's Avatar
Probably not CV joints. They should make a click-click... when you make tight turn.
Since you did not get a wiggle at all I am thinking brakes or wheel bearing. Did you do the brakes yourself or a mechanic?
I agree with UseYourNoggin that the hardware could be at the root of this.
Maybe you look at some Youtubes "grinding noise on the front". If you are lucky you may find one that sounds just like yours.
Old 11-26-2012 | 02:02 PM
I had it inspected at a shop and took them a couple of hours to find the source of the noise and said it was the sway bar bushing. They want $345 for parts and labor which I thought was too much.
Is it safe to drive the car knowing the bushings need replacement?
Is it easy to do the replacement?
