Help adjusting the front washer jets
Old 08-05-2013 | 03:48 PM
monkeyinawalnut's Avatar
Default Help adjusting the front washer jets
Somehow, on the driver side the water jets are pretty much squirting on to everywhere but right where you need it!
With previous cars Ive owned, inserted a pin and gently moving is all thats needed to adjust them but that doesnt seem to help.
Anyone got any advice on how to do this?
Cheers
Old 08-06-2013 | 04:27 AM
Use a very fine pick, they gunk up and jam.
Old 08-28-2013 | 03:45 AM
ok thanks grim reaper..i'll persevere with the pin.
Old 08-28-2013 | 06:22 AM
I use a very small safety pin to clean them out, then a pick to adjust then.
Old 08-28-2013 | 12:36 PM
I don't know about yours, but mine are non-adjustable. Three little plastic jets that are molded in, or prepositioned. All you can do is clean them.
I usually go one step further, perhaps safer than the pin/pick method: What I usually do about once every two years, is remove the jets mounted on the hood and flush them out using compressed air from the front, forcing any accumulated dirt back out the way it likely came in.
This also gives you an opportunity to clean up all the crud that collects under the jets,
Old 08-29-2013 | 05:14 AM
virgin1, do your washer jets look like this?
If so they are fully adjustable.
rdfloyd
04-24-2010 07:24 PM
rikardo76
01-23-2009 02:01 PM
mrwedm4020
04-18-2007 10:22 PM
MarioMaverick
01-20-2007 07:46 PM
mazdaug
07-29-2006 01:14 PM
Quick Reply: Help adjusting the front washer jets
