how do I remove the front passenger door panel?
It's just like on the 3. The panel is held on by two screws, a bunch of plastic push anchors, and the top of the panel hooks into the door panel. The anchors look like this give or take.
-Remove the two screws.... should be in the door release "bowl", and one in the arm rest
-next start grabbing around either the front back or bottom of the door and pull the plastic panel away from the door to pop the anchors loose. The anchors are mostly around the sides and bottom edges, however there's at least one more towards the center of the door.
-DO NOT PULL THE TOP OF THE PANEL AWAY FROM THE DOOR
-once you have all the anchors released slide the panel up to clear the hook from the window channel
-unplug any electrical connectors and set the panel aside.
CharlyFh
02-02-2014 08:53 AM
