Key/Immobiliser problem
Immobiliser light always on
Hi Guys
I own a mazda etude 1.6ie 2002 model it got submerged in water recently I've left it to dry in the sun the problem is the immobiliser light is on constantly and the car does not want to start it goes on and crank like you can kick start it but does not start.
Please help me I don't know what to do is there a way to by pass the immobiliser and if that is the not the solution what can I do.
Here is my problem.
The immobilizer light should flash slowly whenever the car is off. If when you put the key in the ignition the light begins flashing quickly then that means the car doesn't recognize the RFID.
While I haven't submerged my flip key I have had it out in wet conditions, rain, dropped on the ground in rain, etc. The RFID chips should be sealed in a little plastic container inside the key part of the housing, and I doubt that incidental wetness would cause an issue like this.
If the light isn't flashing quickly then it's time to start looking for other issues..... starter, starter relay, clutch switch (if MTX), Park switch (if ATX). If you have an ATX try starting it in neutral.
Hi
Just wondering if you found out what the problem was and how was it fixed. Im currently having the same problem.
I know this is an old thread so chances are that i will not get a reply but i have my fingers crossed that you still visit forum.
Hopefull.....
Hopefull.....
sirius60_uk
12-27-2018 07:45 PM
jackrmee
04-24-2012 08:38 AM
thaiball
11-18-2010 03:34 PM
