Mazda5 - hazard light come on by themselves = dead battery
Old 09-26-2012 | 12:56 PM
rabbitcom1's Avatar
Exclamation Mazda5 - hazard light come on by themselves = dead battery
Our 2009 Mazda 5 has a unwanted feature which has popped up.
while parked the hazard / warning lights come on by themselves.
4 days ago it happened in the middle of the night and the battery was dead by morning.
Today - it happened in the middle of the day but my wife noticed it before it drained the battery -
the only other time was 4 months ago in the middle of the night ..... dead battery !
Anyone had the same issue? solutions? suggestions? (besides exorcism)
love the 5 but can't live like this .... thanks for any help you can provide.
Old 10-25-2013 | 03:13 PM
vonigan's Avatar
This happened to me last night..
It's been preceded by the hazard light button giving trouble to operate - sometimes I press the hazard light and it doesn't stay on; other times it does. I'm thinking it has something to do with the button itself, so I'm gonna open up the dash sometime soon - I'll let you know how it goes!
Old 05-03-2014 | 02:08 PM
RiverdaleDIY's Avatar
I have a 2008 Mazda5 GT with the same hazard light issue. The lights do not always stay on when the switch is activated, they work for a while then stop and the restart again. Not only that but like the OP I came out to the garage in the morning and found the hazards had switched themselves on over night thus resulting in a dead battery.
So my questions are:
Where is the hazard flasher located on this vehicle. I have seem some talk of it being built into the Body Control Module but not sure if this applies specifically to a 2008 M5.
Replacing the flasher (if possible) is likely a good place to start. However, if that doesn’t solve the problem has anybody had any luck opening up the switch and actually repairing it as opposed to forking out $150 for a new switch?
Thank you very much.
Old 05-03-2014 | 03:00 PM
I have looked at the fuse block under the hood and none of the relays etc. in there are marked flasher or hazard. There is a 10A fuse under there for the hazards but that checks out fine.
The clicking/blinking noise, when the hazards are activated, sounds like its coming from right up under the dash, above the pedals, behind the instrument cluster.
Old 05-13-2024 | 01:35 PM
Woodbanditry's Avatar
Default Hazard button problem
I have a similar problem. Any solutions? Is it a bad flasher unit or the switch itself? How hard is it to get to the switch?
JimsMazda3
11-27-2022 03:23 PM
tfw13579
11-11-2014 11:22 PM
JDStar
07-26-2008 06:34 PM
gregno
02-28-2008 10:51 AM
David
07-20-2007 11:16 AM
Quick Reply: Mazda5 - hazard light come on by themselves = dead battery
