Mazda5 Radiator Support Replacement Question
Old 07-13-2019 | 08:27 PM
Aaron Johnson's Avatar
Question Mazda5 Radiator Support Replacement Question
Last week, I noticed that our lower radiator hose was leaking. Taking a closer look, the hose had touched a pulley and had a small cut in it. Taking an even closer look, I noticed that the radiator, on the driver's side was angled out toward the engine. This must have happened when a family member went off the road this winter, but just now creeped close enough to create the pulley/hose issue.
All that to say I'm replacing the radiator support, also called the radiator shroud. My question is about the metal mounts/brackets that the shroud connects to. The passenger side one is bent pretty badly. I think there is an upper and a lower and it's the lower I'm concerned about.
1. Should I just bend it back? I've bent it back a good bit so far (see pic) and I plan to bend it back straight when I do the replacement fo the shroud, but I'm concerned the metal will become too malleable and could bend back. Probably not likely, but thought I'd ask.
2. Is it a bracket that I can order and replace? (see pic)
3. Is it part of the bumper reinforcement? (see pic) It's hard to tell from what I can see without removing everything. If it's something where I also need to replace the bumper reinforcement in order to replace the bracket (part of the system is welded on), should I then be replacing the bumper reinforcement. I'm guessing that's unnecessary, but I thought it was worth asking before I got too deep into the project. I'd also like to order all the parts before taking things apart.
Thanks ahead of time to those reading this.
PS: Parts Notes:
  • The bumper shroud ranges from about $80-350. Some places that have it cheap charge about $100 to ship it! The best supplier I found was carparts.com
  • I also found the under cover/shield from https://www.realmazdaparts.com/
  • The lower radiator hose was impossible to find and the dealership wanted $50 for it. I also found it for about $20 at realmazdaparts.com
rcmaflyer
11-03-2018 03:12 PM
jeepwm69
08-23-2016 02:42 PM
sweetcoupe
04-20-2010 10:40 AM
turbo_miata20
07-08-2006 09:57 PM
mydogduster
10-19-2005 01:00 AM
