Missing Antenna Mast 2008 Mazda5
Old 02-06-2009 | 04:44 PM
Siber Express's Avatar
Have you tried using a screwdriver to remove the piece at all?
Old 02-06-2009 | 05:04 PM
sapacif's Avatar
Smile
I'm not sure how. There is no slot or phillips groves to use a screwdriver. I have tried using a pin to try to turn it. It will be easy to go by the Mazda place and ask them; I expect they have seen it before. I'll report back on that as soon as I have some info.
Old 02-07-2009 | 04:43 PM
sapacif's Avatar
Smile
Got it fixed at the local Mazda dealer as I couldn't figure out how to get the broken "plug" out. I asked how much it would be.
89 US$ for unscrewing the plugged part and adding the antenna. Forty-five minutes time. Then,
130 US$ to drill out the plug as it will not unscrew. Then,
210 US$ to replace the mast base as it is "cracked." Then,
Two hours labor to drop the headliner in the rear to get to the mast base from the bottom.
I complained. They gave me some relief on the labor so the total cost was 220 US$. Three hours later it is fixed and it works much better on the AM radio.
Last edited by sapacif; 02-11-2009 at 05:43 AM. Reason: Add or clarify information
Old 02-07-2009 | 07:40 PM
Glad you got it fixed.
To bad you didn't see it before you bought it, the dealer could have had it fixed before delivery.
Old 11-02-2009 | 04:53 PM
heywatchit's Avatar
I just snapped off the antenna on my Mazda5. A long antenna like that on top of a tall car is bad design. I tried to unscrew what was left with pliers but could not. I just bought a new base and I was hoping there was a way to replace it without removing the headliner but it looks like I will have to. I might try drilling out the broken plug first. I don't suppose there are directions for how to remove and reinstall the headliner anywhere? Thanks.
Old 11-07-2009 | 02:15 PM
heywatchit's Avatar
Default How to replace antenna on Mazda5
I figured it out on my own. Photos and directions here: http://cid-a11ab21b76c441bc.skydrive...s&sa=595337876
turboturney
09-12-2019 02:51 PM
Brad Lehman
01-09-2010 11:44 AM
old929guy
09-09-2008 09:02 AM
sbeears
12-30-2007 08:36 PM
Am4wag
12-21-2007 08:34 PM
Quick Reply: Missing Antenna Mast 2008 Mazda5
