Mudflaps
Mudflaps
I saw a post about the lack of guards on these cars and the fact that, without them, because of the way the panels are shaped, rocks kick up from the tires and can cause chipping and eventually rusting to the lower panels. I was looking around and didn't see anything for the 07'. I was wondering if anyone knew where I could get some?
RE: Mudflaps
I used those mudflaps that you can get from canadian tire or walmart.
and followed this guy's procedure: http://www.filtsai.com/sti/mudflaps/index.php
RE: Mudflaps
Installed my $36 (from dealer) front splash gaurds in about 10 minutes. Two screws, two anchors each. The 07 accessory catalog states they will not work with side sill extensions.
Though the instructions mentioned and showed a plastic piece that ran the length along the underside of the rocker panle called the "rock plate"that needed trimmed to fit the guards. My 07 did not have this and I am looking for a part number to order it as I would like the added protection on the undercarriage.
