oil
Do a cylinder compression test follow it it by a wet compression test.
Then you may need to do a cylinder leak down test.
When doing the test do not let the engine rotate more then 5 revolution or your test will be inaccurate.
I would also check your PCV system for to much oil .
You can also check the tailpipe for a black semi wetness that would indicate oil consumption through the engine.
Check the spark plugs for an indicator of oil fouling
